: oxygen sensor removal
Harry Yarnell
08-24-10, 12:46 PM
'97 Seville
How do you remove the rear oxygen sensor; the coolant pipes are in the way. Also looks like the A/C blower may also be in the way.
Shoulda replaced it when the engine was out.:yawn:
Krashed989
08-25-10, 12:22 AM
How I did it was I sat on top of the engine and used a long extension with one of these guys (O2 sensor crowfoot) on it. Seemed to do the trick.
http://toolmonger.com/wp-content/uploads/2009/10/o2-sensor-cuss-guard.jpg
KHE
09-02-10, 02:07 PM
The shop manual states to lower the rear of the cradle down enough to gain access.
H-Dmechanic
09-06-10, 12:17 PM
i have the same issue, what is the procedure for lowering the rear of the cradle?
johnny kannapo
09-10-10, 12:06 PM
When I R & R 'ed the fan motor I could clearly see the O2X sensor and believe it can be changed from the top-dog bones removed & engine tilted forward 2".
Why do that?
On my Eldo its in the open accessible from the bottom. I believe The 96 yr model Eldo & Deville are more alike than the Seville.
Get the front of the car off the ground 8 or 10 inches & take a peak. It's pretty much wide open.
http://i826.photobucket.com/albums/zz183/billytheshoe/cca3a270.jpg
