Hello All -
With the help of PGA, PJ, and our good friend Russell, I was able to get my lowering springs installed prior to my trip to woodward dream cruise in michigan this past weekend.
I'd like to thank russell for allowing me to use his spacers until D3 sends me mine, and PJ for coming into cleveland to give them to me so I could get them installed in time. This is a very close knit, tight community and I am proud to be a member with my fellow STS-V owners.
Lets get to the good stuff:
The springs were easy enough to install. The rears fall out when the control arms are detached, and the front come off with a spring or strut compressor. I had two mechanic friends over, and it took about 3 hours. Pictures are attached with their respective file names.
Heres the bad stuff:
The car is way out of aligment. After taking it to a normal aligntment shop, and then a performance shop that does corvettes, my camber is still almost 2 degrees out of alignment. The shops say I need caster/camber adjustment plates - which they do not make for the STS. I have bought camber adjustment bolts, but they only adjust up to 1.25 degrees. Anyone have any ideas? I called D3, and they said they just get it "as close as they can" which is pretty unacceptable from how hard my steering wheel pulls to the left on the highway.
My recommendation? Do not buy them until someone can figure out how to properly align these cars. if anyone has any suggestions, please let me know.
Thanks!
Thanks!
