: 1968 Deville Blinking Brake Light
durrett syndrome
08-23-10, 05:07 PM
Hey everyone I have a 68 deville and the brake light will blink front time to time if im hard on the brakes...I just got the car and see no leaks around the master cylinder and i dont see how I can get into the master cylinder to see if the fluid is low????? weird but any help id really appreciate. Thanks.
Angry Matt
08-23-10, 06:08 PM
Doesn't the reservoir have two metal straps that you snap down and the cap pops off to check the fluid? It should be right above the booster.
08-23-10, 11:48 PM
I have had the same problem. Your brake pedal is too low. There is a plunger in the master cylinder that is traveling too far and activating the dash "BRAKES" light. You need to bleed your brakes and if you still have the problem, check to see if your brakes are properly adjusted. If the shoes are spaced too far from the drum, this would also give you a low pedal.
