View Full Version : 1991 Brougham De Elegance instrument cluster
rustfarmer
08-20-10, 08:56 AM
Instrument cluster went blank 8 months ago and shop replaced "computer driver" with used unit. This worked for about 6 months, then problem started again and at first I could hit the dash and display would re-appear, but now dash is blank and hitting no longer works. Ideas?
outsider
08-20-10, 10:11 AM
Maybe the used unit was defective? hitting it to have it turn back on leads me to believe something was loose inside of it to begin with.
rustfarmer
08-20-10, 02:33 PM
Used unit worked fine for 6 months, then began to fail same as old one so I was wondering if some other bad part might be eating these up?
brougham
08-20-10, 03:30 PM
It's a common problem so it was probably just the used part's time to die. You can always check and see if the plug got loose tho.
csbuckn
08-20-10, 04:43 PM
Make sure your fuses are the correct size. Too big would cause extra heat and more than needed current. I have an extra cluster if you need.
brougham
08-21-10, 06:37 AM
Wrong size fuse just won't blow when it's supposed to.
rustfarmer
08-21-10, 10:42 AM
Make sure your fuses are the correct size. Too big would cause extra heat and more than needed current. I have an extra cluster if you need. How much for cluster? Is there a part called a "computer driver"? What is it and where located? Thanks.
csbuckn
08-21-10, 10:49 AM
Not sure what the computer driver is. I sent you a PM.
jayoldschool
08-21-10, 10:55 AM
The problem is likely cold flow solder joints or contacts that have worn where the display module contacts the board. It can be fixed by re-flowing the solder.
rustfarmer
08-23-10, 11:17 AM
Excellent information. I have seen similar problems on other makes and this sure fits the pattern. Thanks very much.
rustfarmer
08-23-10, 11:25 AM
Thanks, read your PM and price is very reasonable. Forum would not allow me to use PM system cause I'm a newbie. I will pull my cluster within a week or so and let you know if I need yours. Shipping would be to 37033.
