View Full Version : 2010 SRX paint coming off center console
lorr2000
08-19-10, 09:04 AM
The other day, I saw what looked like a spot on my console, next to the drive shift indicator window. I licked my finger, to wipe it off, and discovered that it was not a spot -- the finish was coming off the painted plastic! Anyone else having this problem?
sube5186
08-19-10, 09:43 AM
Need to see pics!
Just from the location you described, it sounds more like the part wasn't properly painted from the factory, then it does wear. The reason I say this is because that area is normally not a place you'd ever touch. But again, I'd need pics to give a more accurate opinion.
Sube
lorr2000
08-19-10, 10:47 AM
I'll try to take a picture tonight. Thanks!
Cooper10
08-19-10, 04:08 PM
Instrument Panel Side Trim Panel was just replaced last week due to the brownstone coating was peeling off.I have a feeling
in time the top of the dashboard will peel off. GM uses a vinyl paint that is applied over the same color soft plastic material below. The salesman told me that this happens to all of the Escalades on the center console cover over time.
adamjeeps
09-12-15, 08:59 PM
Just found this today on ours peeling off down by the seat belt buckle. It's in an area that never gets touched. Hopefully the dealer does not try to say its not covered. Also noticed there is no felt pad behind the driver seat belt buckle like on the passenger side. Either its missing or they assume it's not needed since the driver side should always be buckled and therefore would not rattle.
Sent from AutoGuide.com Free App (http://www.autoguide.com/mobile)
stevec5375
09-13-15, 09:36 AM
I have some black spots on the console near where the seat belt fastens.
