: 95 PCM question
Pete315
08-13-10, 05:44 PM
If I put in a used PCM in my 95 Eldorado with same serial numbers and same 4 letter code, do I have to have dealership reprogram the PCM with my vin?
AJxtcman
08-14-10, 08:27 PM
You should try to retain the stock memcal. That is the chip inside the PCM. The memcal has a calibration built for your list of options and emissions. The boxes interchange on OBD1 cars. I don't see the VIN in the calibrations that I have for OBD1 cars
Pete315
08-15-10, 02:46 AM
how do I remove that chip? I guess I have to open the PCM.
AJxtcman
08-15-10, 11:22 AM
The PCM has a cover that you need to remove to expose the memcal.
Pete315
08-16-10, 09:24 AM
Is the memcal also called the PCM Prom? I can't find anything in the shop manual about a memcal.
AJxtcman
08-16-10, 12:00 PM
Yes. GM called them Proms and on the later cars they called them Memcals.
Pete315
08-16-10, 12:42 PM
ok. thanks for your help. I appreciate it.
