: 2000 ETC, vin 9, will seville/deville vin 9 motors fit?
08-08-10, 05:32 PM
I'm shopping for a replacement engine for my 2000 ETC. I see some motors on Ebay listed for Seville & Deville with vin 9, will these fit in the ETC?
08-08-10, 06:45 PM
2000-2003 engines only. Your engine has the later roller cam followers, some different electronics and engine control sensors, and a few other differences. There MAY be a difference in motor mounts from the Seville/Deville engines - check first.
08-08-10, 07:40 PM
So as far as you know the engines themselves will fit by using Eldorado specific engine mounts, exhaust manifolds, etc?
08-08-10, 09:38 PM
Check the engine swap sticky at the top of the Northstar forum.
08-13-10, 10:34 PM
Being its an ETC only the older K/E body N* will work, which in the case of an 00+ only a 00-02 Eldorado ETC Vin 9 engine will work.
08-14-10, 03:27 PM
If you need a brand new engine built for your '00 ETC, let me know. I can make you a bit of a special deal: I can offer you everything new including the water crossover, all sensors including CKPs, cam pos. sensor, IAC, TPS, MAP, GM rods, pistons, bearings, rings, my studs (of course), new water pump, egr valve, intake manifold, intake plenum, throttle body, injectors and even the fuel rail for your ETC. 5 year warranty. Built with GM seals and gaskets to their specs. 100% new. I'll see if I can post a pic a bit later-
