View Full Version : 1999 sts
Cadillacman1968
08-07-10, 09:37 AM
Hey I have a bad N* of course, my question is can I swap in a 95 vin y as far as bolting in, I'm changing the cams anyway, just wondering what year engine I can use without all the trouble of trying to move connectors and stuff. Thanks Bruce
Ranger
08-07-10, 11:06 AM
The '95 is a 4.9 and I doubt that will work. Not to mention it is OBDI and your car is OBDII. Check the sticky on Northstar swaps at the top of the forum page.
ejguillot
08-07-10, 11:37 AM
To the OP:
What went wrong with your Northstar? If it's the headgasket issue, the various members of this forum have had a lousy track record with engine replacement as a fix - most have seen another failure within 20,000 miles.
You're better off fixing the one you have.
CadillacSTS42005
08-07-10, 12:18 PM
The 95 SLS has a vin Y LD8 Northstar, he even states he wants to use a Vin Y
to the OP no you cannot use that engine
ponyboyt
08-07-10, 01:08 PM
To the OP:
Just as a heads up, i had a thread going way back where i did a swap with that exact situation. My 97 had about 300,000 km's on it when the gaskets went, it just rolled 350,000 the other day. The engine came from a 95, but that 95 had had the engine replaced in '02 so the block had provisions for all those years. Oh and... it doesnt burn a drop of coolant. Burns lots of oil though!
Not to say this is the best route, i would much prefer the proper rebuild... but for what i paid i did ok. If its a nice low-k car its worth going the extra for a stud kit / timesert.
Ranger
08-07-10, 10:13 PM
Oops! My apologies. I was thinking Deville. Thanks for the correction CadillacSTS42005. It is a Northstar, but the difference between OBDI and OBDII still applies.
CadillacSTS42005
08-08-10, 02:48 PM
Np just making sure we were on the same page haha. In 95 wasnt the N* and option and standard on the concourse then in 96 it became standard on the Deville correct?
Ranger
08-08-10, 05:04 PM
Not sure if it was even available in '95 in a Deville. Standard in the Concourse I think. I believe you are correct in that it became standard in '96.
