View Full Version : Stability System and Anti-Lock Braking System !
doowap57
08-01-10, 05:39 PM
I have read here, that some members think these are the same thing.
I somehow do NOT think so.
Would some knowledgeable member please eliminate the confusion,
between the two above ?
Thank You...:cool2::cool2:
I have just read it in the Owners manual, that these systems are
associated.
doowap57
08-01-10, 09:46 PM
I have since posting the above, have pulled this OUT of the owners manual,for
ALL to read.The "Stabilitrak system "IS" associated with the ABS system.
Thanks to all.:confused:
CadillacSTS42005
08-02-10, 09:37 AM
They arent the same
Anti lock prevents you from panic locking any of your wheels sending you into a skid which you lose all control
Stability system prevents you from going sideways when it detects too much yaw and body roll and the car is moving in a direction not interpreted to be correct with where you have the steering wheel turned (via the steering wheel position sensor)
sub613
08-04-10, 04:41 PM
AND ! it does this NOT by anti-Locking brakes, but by applying the "brakes"
as needed to make ,the vehicle stable.
SlickCityStan
08-05-10, 12:20 PM
Traction Control and Stabilitrak both use the Anti-Lock Brake System to function in their prescribed manner. If the ABS malfunctions then Traction Control and Stabilitrak will not function correctly.
EChas3
08-07-10, 05:50 PM
Actually, an ABS fault will deactivate Stability System, Traction Control & Adaptive Cruise Control.
