: ABS module
07-26-10, 07:50 PM
Does a used abs module need to be programmed at the dealer to work right? I think that is what operates the stability control and I'm wondering if that just needs to be flashed. I have the original module so I might just put that back in but it's a huge pain to bleed the brakes for something that might not work. I replaced it because the pressure sensor is broken and the parts car had a good module.
07-27-10, 07:01 PM
This is killing me, somebody has to have an opinion. I want to sell this car and I can't do it until this works.
07-30-10, 09:48 AM
EBCM Replacement
If the electronic brake control module (EBCM) is replaced, the following procedures must be performed:
EBCM Reprogramming-Refer to Service Programming System (SPS)
Recalibrate the brake pedal position (BPP) sensor
Recalibrate the steering angle position sensor
Recalibrate the yaw rate sensor.
