View Full Version : battery change problem
plain97
07-16-10, 10:51 PM
just bought a 05 sts,battery is dead,changed battery but when i hook up the battery cables the lights blink on and of as well as the horn blows with the lights,cant get in the car ,can some one help?
EChas3
07-16-10, 11:15 PM
Press unlock on the remote to reset the security system. If you don't have a remote that is matched to the car, use the regular key in the driver's door to unlock the car.
turnerbend
07-16-10, 11:19 PM
Do you have a key for the door? Check the rear doors, one of them should be unlocked. If that don't work, do you have the F.O.B?
plain97
07-16-10, 11:19 PM
dont have a key,do i press the unlock button and hold it down while it is alarming or exactly how do i do it?
turnerbend
07-16-10, 11:45 PM
This is from the manual. It could help maybe.....
Q(Lock): Press this button to lock the doors. The
lock status light on the front doors will turn on for
five seconds and the turn signal indicators will flash. If
this button is pressed twice, the doors will lock, the
status light on the door will turn on for five seconds, the
turn signal indicators will flash twice and the horn will
sound once. Press and hold the lock button for
more than two seconds to close any open window(s) on
your vehicle. If any window is unable to close
completely, it will reverse and the horn will chirp. See
“Anti-Pinch Feature” under Power Windows on
page 2-17 for more information.
You can program your vehicle so the turn signal
indicators will not flash and the horn will not sound
when pressing the lock button on the keyless access
transmitter. For more information see “Lights Flash
at Lock” and “Horn Chirps at Lock” under Vehicle
Personalization on page 2-47.
/(Remote Start): Pressing this button operates the
remote start feature. See “Remote Vehicle Start” at
the end of this section for more detailed information.
K (Unlock): Press this button once to unlock the
driver’s door. The turn signal indicators will flash twice.
Press the unlock button twice within five seconds to
unlock all the doors. If it is dark enough outside, your
interior lamps will come on.
indicators will not flash and the fog lamps and reverse
lamps remain on steady for approximately 20 seconds
when the keyless access transmitter is used to
unlock the vehicle. See “Lights Flash at Lock” and “Ext.
(Exterior) Lights at Unlock” under Vehicle
If your vehicle has the memory feature you can program
and recall memory settings when you press the unlock
button on the keyless access transmitter. See Memory
Seat, Mirrors and Steering Wheel on page 2-64 for
more information.
G(Trunk): Press this button to open the trunk
while the engine is turned off or the shift lever is
in PARK (P).
L(Vehicle Locator/Panic Alarm): Press and release
this button to locate your vehicle. The horn will chirp
three times and the turn signal lamps will flash
three times. Press and hold the button for three seconds
to sound the panic alarm. The horn will chirp and the
turn signal lamps will flash for 30 seconds. Press
and release the button again to cancel the panic alarm.
EChas3
07-16-10, 11:46 PM
Just press Unlock.
You will need a dealer or a locksmith to get a real key. You'll need one to match Fobs to your car.
plain97
07-16-10, 11:52 PM
found it ,battery in the key fob was dead,thanks
