: Cadillac sts v6 engine!!!!!!!!!!!!!!
Jeremy59
07-12-10, 04:47 PM
So i tend to have a lead foot, well my car runs great its got flowmasters, intake, and well she hauls ass till she hits 115 and then falls flat on her face. The pedal isnt all the way and im no where close to redline. I also notice when the car is in park it will not rev up over 4,000 rpms. I am a little bit confused on whats going on. I am sure she has a gov, but is there any tuners to change all that. I know they have them for the v models. A buddy of mine has a g35 with a 6 in it and i can kick its ass all the way until 115 then he comes flyn by me.. kinda pisses me off :nono: any ideas or suggestions to give it some pep ,
CadillacSTS42005
07-12-10, 04:59 PM
Yea buy a V or at least a N*...
Seriously though the 05 3.6 has been hacked so a dyno tune will remove the limiter but gains will be in the 10-15 hp max...
Jeremy59
07-12-10, 05:10 PM
im going to try to find a tuner , hopefully it will work out. Now as far as getting a v or northstar lol im only 23 and the v i could only wish of right now and i did want the northstar however insurance would have gone thru the rough, so for now im stuck with my 23.4 miles to a gallon and trying to get all i can out of the baby northstar ...
next2pool
07-12-10, 05:15 PM
It's not a power issue--you are hitting the rev limiter. It's set based on the original tires which probably weren't V rated. A Tech II tool can reset that but not all who have one will do it.
CadillacSTS42005
07-12-10, 05:22 PM
Dyno tune will kill the limiters as well as add a bit more hp and tq as well as adjust shift points.
next2pool
07-12-10, 05:38 PM
Definitely agree.
SlickCityStan
07-12-10, 05:59 PM
where would you go to get a dyno tune?
next2pool
07-12-10, 06:10 PM
In our Phoenix area, I frequently see dyno tune services on Craig's list, but that of course varies by area. Might be worht a check depending on the size of your town or one close by.
Jeremy59
07-12-10, 06:21 PM
thanks for the help guys im deff going to check into that , what is a fair right to pay? Never messed with dynos to much :stirpot:
next2pool
07-12-10, 06:35 PM
Depending on what you actually want done, I recall a minimum of $200
CadillacSTS42005
07-12-10, 06:42 PM
Depends if the Dyno place has the credits already unlocked for your car (if they tune with HP tuners) or experience with tuning through Westers (there are other tuners but those are the majors).
Im having my 98 LS1 SS Camaro tuned, a pretty easy car as far as tuning goes as well as alot of tuners have experience and its costing me 550 bucks.
Its not cheap, you have to pay to play...
next2pool
07-12-10, 07:03 PM
I just checked Craig's list in this area and it looks like around double of what i thought--generally $400.
CadillacSTS42005
07-12-10, 07:13 PM
200 bucks is in the neighborhood of a mail order tune. Worthless compaired to a real Dyno tune.
Jeremy59
07-12-10, 11:09 PM
has anyone done this and had good result on the v6
MGD
07-14-10, 03:53 PM
How are you getting 23.4mpg?? I'm only getting 18mpg in mine and I barely ride her that hard on a regular basis!
Jeremy59
07-14-10, 05:41 PM
I have always got good milage out of this car, never below 21.9 and thats when im haulin ass everywhere.. I really started getting better milage running 89 and up octane. My car always seems to run cleaner and it seems its pick up response is a little better then regular gas. I also have intake and exhaust, which they say the intake helps some with gas milage. The intake helped alot tho with the hp and low end . I have changed the fuel filter every 8,000 miles as well and run a can of berrymans thru it once a month or so. I am a reg at changing the oil to, with mobil one i will run 4,000 but at 2,000 i have to ad a quart( i called cadillac when i first noticed i was having to add oil at 2,000 and they said thats within spec) and i gues the last thing i due is i clean the throttle body every other oil change, right when the intake comes in and where the slide is it gets carbon pretty bad. Other then that i drive the wheels off of it. I have heard that the harder you drive these cars the better they run.... and for me instead of babying it everywhere , it tends to run better if you lay into it every once in a while
kschwed
07-14-10, 07:58 PM
Thats awesome gas mileage. I primarily do just around town driving, but I do drive it hard. I'm only getting about 16mpg. How do you clean the throttle body?
Jeremy59
07-14-10, 08:30 PM
You would take the intake tube off the housing of the throttle body and get some throttle body cleaner and spray n there... You will see a bunch of black residue and that's the carbon all built up.. Leave the intake tube off and start ur car, it will b hard to start for a second and when it does start it will not run good for about a min or two. That means the throttle body cleaner is doing it's job.. Ur exhaust will smell funny but when ur car idles back up turn it off and repeat until completely clean.. If u have alot of build up u will notice ur throttle response will b better, if u run higher octane u will get a better and cleaner burn which will reduce the carbon... I think these cars run better on 89 plus octane. Just my two cents
kschwed
07-15-10, 12:31 AM
Yeah my throttle response is shitty. Could you possibly elaborate a bit more on where throttle body is that I am supposed to be removing the intake tube from. I'm sorry but I dont know a lot about the mechanics of cars, just the 12v system.
porkfarm
07-16-10, 04:24 AM
I get over 21 in my N* and it has the tall gears and see's 80MPH daily. I think I got the car as close to perfect as I can and it only took me 60K miles.
Loren
07-17-10, 12:45 PM
Here's more about cleaning a throttle body than you probably wanted to know. One of those Google URL's.
http://www.google.com/search?hl=en&source=hp&q=2008+cadillac+throttle+body+cleaning&cts=1279384821320&aq=f&aqi=&aql=&oq=&gs_rfai=CiSXD9dxBTJScO4GgjgPstOyMDgAAAKoEBU_QE4RH
