View Full Version : super charger snout porting
lawnstripes
07-11-10, 10:36 PM
so i have the snout off the car and started my first try at porting the snout and getting the inlet ready for a 90 mm throttle body
i still have more work to do but if there is anything else(secret areas) to hit let me know.
thanks for any help- guidance
http://i778.photobucket.com/albums/yy68/lawnstripes/Mobile%20Uploads/IMG00247-20100711-2049.jpg
http://i778.photobucket.com/albums/yy68/lawnstripes/Mobile%20Uploads/IMG00248-20100711-2050.jpg
http://i778.photobucket.com/albums/yy68/lawnstripes/Mobile%20Uploads/IMG00250-20100711-2051.jpg
wait4me
07-12-10, 12:21 AM
The top part you ported was a waste of time. That is for the internal bypass. It does nothing for horsepower.
lawnstripes
07-12-10, 08:04 AM
thanks Jess- i figured that.... but when you lift off the throttle the air will flow alittle smoother now.
So......... what else on the lower section to help power?
Paschal Performance
07-12-10, 03:19 PM
Joel
Give us a call.
wait4me
07-12-10, 03:49 PM
Maybe someone that has one of ours will show you what we do, I make a lot of changes, including grinding off alot of that bolt material you can see in your first picture, and increasing the size on the smaller side of the unit, it helps alot on feeding the front of the rotor pack. I also change the rear entry on the mounting area on the blower itself, that makes a major change.
For the people that send us the snouts, we only charge $100 for the porting on it and the throttlebody for a few more weeks.
SSideways
07-12-10, 04:52 PM
Is this hand porting or CNC porting?
lawnstripes
07-12-10, 05:03 PM
i would think it would be hand ported.
Umrswimr
07-12-10, 05:41 PM
How much power is this worth?
PhxTriode
07-12-10, 07:44 PM
Jesse,
At what HP level do you feel this mod would have the greatest gain?
lawnstripes
07-12-10, 08:20 PM
Jesse,
i would think at any time you port would be good.......... the easier/better airflow in = hp
wait4me
07-12-10, 10:26 PM
stock = 1 hp.
9.5 pulley or 2.55 upper equivilent is about 6.
at 600 hp level, it is about 11 gain with the tb and snout.
The blower caseing assembly adds 34 or so to the above numbers when done in conjunction with each other.
gonfishin
07-12-10, 10:54 PM
stock = 1 hp.
Man, I gotta get my blower case asembly done :drool:
lawnstripes
07-12-10, 10:56 PM
stock = 1 hp.
damn- wish the wife could handle having her car down for a longer amount of time to send it out to you........ "free hp" :bouncy:
Umrswimr
07-13-10, 09:31 AM
stock = 1 hp.
Wow.
Ok, that ain't worth the hassle.
PhxTriode
07-13-10, 12:17 PM
[/B]
dupe
