View Full Version : Rear axle swap 96 brougham
Eric Kahn
07-06-10, 06:27 PM
Has anyone done a rear axle swap or gear ratio change on a 94-96 brougham, would like to know hwo much of a pain it is to have the speedo adjusted if the axle I get is not the same ratio as the one in it
jayoldschool
07-06-10, 09:09 PM
The speedo is adjusted by changing the programming in the PCM (computer). This is done with a special cable that connects to a computer that is running the appropriate software. You can buy the cable for around 50 bucks. Or, you can send your PCM in to get reprogrammed. For cables, I suggest AKM, and for programming check PCMforLess.
csbuckn
07-06-10, 09:15 PM
What about changing the speedo gear? Does that work in this situation?
jayoldschool
07-06-10, 09:18 PM
No speedo gear in the 94-96. The trans is the 4L60E, the E meaning electronic. There is a VSS that sends the pulses to the PCM, then to the speedo.
Stingroo
07-06-10, 09:33 PM
Jay wins.
Maybe he can score another victory on the other forum. lol
cason234
09-27-10, 12:24 AM
to echo what jay said, I had the gears in my 94 Fleetwood swapped to 4.10 gears and a posi. I had the PCM retuned for a bunch of other things as well, but the speedometer correction was part of the equation. It was straightforward and easy!
N0DIH
09-27-10, 01:25 AM
Yup yup....
Was thinking of swapping mine to 3.90's....
