View Full Version : retained assy power
eldog90
07-29-03, 03:37 AM
ok here it is ,my 90 etc retained assy power does not work.it did but now it does not,but my power windows and trunk fuel dooretc all work long after key is removed or door is opened pls help
2dfx
07-29-03, 08:10 PM
Fuse?????????????
Katshot
07-29-03, 10:14 PM
You DO know that everything's not powered through RAP right? Matter of fact, it's only the radio, windows, etc.
So what makes you think RAP is NOT working?
eldog90
07-29-03, 10:40 PM
well i dont think its workin because its supposed to go off after you open a door or in so many munites right?well my windows ,trunk .gas door all work all the time they dont cut off and as for the raido it cuts off as soon as you kill the motor/key.i dont belive this is right
Katshot
07-30-03, 08:01 AM
I would agree. I would guess you have a module issue and MAYBE a door switch issue.
eldog90
07-30-03, 10:08 AM
ok i checked door switches,and just to be sure replaced both,no change.so can somebody tell me where the rap module is located.so many little black boxes undere here.
Katshot
07-30-03, 10:26 AM
I believe that's the DERM and it's on the brake pedal support bracket under the dash.
