: 70 Deville Brake rotors
KimKnudsen
07-04-10, 03:32 PM
Hello again and happy 4th ............. :D
I need to buy new rotors and have some questions.
Anyone here had problems with finding rotors that actully fits?
Someone told me that i could use late 70's rotors witout problems.
I only wan't to change the disc's and pads.
I don't wan't to buy 200$ drilled racing stuff.
Just plain rotors that do the job.
When i look at sites with pictures of the discs
they don't have the bolts and nothing in the center?
Is it include all i'll need?
Thanks again :)
carnut
07-04-10, 09:01 PM
You will need wheel bearing grease seals because you will swap the inner/outer bearings to the new hub in the new rotor. Also a can of wheel bearing grease. 70 Cadillac has disc brakes? not drum. If so, the replacement rotors should have lug nut studs already in them. The auto parts store can tell you what other years these rotors fit. Are the old ones too scored to simply have turned?
albymangled
07-05-10, 04:30 AM
only just off topic (sidestep..?).....why is it that the Eldorado rotors are so much cheaper than those for the RWD cars?
http://cgi.ebay.com.au/CADILLAC-ELDORADO-69-70-Brake-Rotors-PREMIUM-FRONT-/370400949256?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item563d9df408 ELDO ($187)
http://cgi.ebay.com.au/CADILLAC-DEVILLE-69-70-Brake-Rotors-PREMIUM-FRONT-/220627494292?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item335e6c6594 DEVILLE ($504)....WTF?
deVille33
07-05-10, 09:56 AM
I don't have my parts guide books here, but I believe you should be able to use the rotors from any Cadillac deVille up to 1977. In 1978 GM changed the bearings they used on front discs and the newer bearings wouldn't fit the old style spindles. The bigger Buicks also used the same rotors with the 5 x 5 bolt pattern.
Neil Clarke
07-05-10, 10:09 AM
From Rockautos website (seem different to me ...the 70 looks slightly larger diameter byt this info )
1970 CADILLAC DEVILLE 7.7L 472cid V8 : Brake/Wheel Hub : Rotor Wiki Price
AUTOSPECIALTY / KELSEY-HAYES Part # AR8232
Front; w/Front Disc & Rear Drum Brakes [Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining)
$69.89
RAYBESTOS Part # 5800R More Information About this Part {Professional Grade; 11.96" / 5 Bolts (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) #5800} Sale Item
Front
$147.79
CENTRIC Part # 12062032 More Information About this Part {Centric Premium Rotor}
Base; Front Disc brakes; Front
* Non-stock item--shipping delayed up to 2 business days
$122.79
ACDELCO Part # 18A1341 More Information About this Part {#89056475}
ROTOR,FRT BRK DURASTOP
* Non-stock item--shipping delayed up to 5 business days
$187.89
1976 CADILLAC DEVILLE 8.2L 500cid V8 FI (S) OHV : Brake/Wheel Hub : Rotor Wiki Price
RAYBESTOS Part # 5006 More Information About this Part {PG Plus; Outside Diameter 11.86" / 5 Bolt Holes}
Front (Only 3 Remaining)
$51.79
RAYBESTOS Part # 5006R More Information About this Part {Professional Grade; Outside Diameter 11.86" / 5 Bolt Holes (Rebate/Promotion Available! See Promotions & Rebates Page for Details.)} Sale Item
Front
$53.79
RAYBESTOS Part # 5006PR More Information About this Part {Advanced Technology Performance; Drilled & Slotted Outside Diameter 11.86" / 5 Bolt Holes (Rebate/Promotion Available! See Promotions & Rebates Page for Details.)} Sale Item
Front; Right (Only 1 Remaining)
$100.79
ACDELCO Part # 18A2 More Information About this Part {replaces 18027602 #18027602, 19195696}
ROTOR,FRT BRK(W/HUB) DURASTOP
$58.79
ACDELCO Part # 18A1122 More Information About this Part {#89000472}
ROTOR,FRT BRK (PERFORMANCE) DURASTOP PERFORMANCE; RIGHT HAND; 11IN ROTOR
$97.79
WAGNER Part # BD60258 More Information About this Part {Brake Rotor/Hub Assy.}
Front
$61.79
CENTRIC Part # 12066000 More Information About this Part {Centric Premium Rotor}
Base; Front
Cabriolet; Front
d'Elegance; Front
$71.79
CENTRIC Part # 22666000SR More Information About this Part {Centric Premium Slotted}
Base; 2 required per vehicle; Front
d'Elegance; 2 required per vehicle; Front
Cabriolet; 2 required per vehicle; Front
$75.79
carnut
07-07-10, 12:32 PM
They are more money because they usually include studs and hubs. A front wheel drive car has no studs or bearing hubs. The rotor simply slips over the studs in the drive axle hub.
