: Timing Chain
ahahnu
07-01-10, 07:01 PM
Does the V have one? Someone was asking me and I have no idea. :hide:
heavymetals
07-01-10, 07:04 PM
YES it does.
814V
07-01-10, 07:15 PM
I thought it was pushrod.. :hmm:
darkman
07-01-10, 07:31 PM
Reading assignment- (yes it has pictures)
http://www.motorbooks.com/Store/Product_Details.aspx?ProductID=42331
heavymetals
07-01-10, 07:34 PM
What do you think makes the cam go around and drives the pushrods?
shadybx7
07-01-10, 07:35 PM
:lol: really mike
april fools right.... in july
this has a timing chain
http://www.babez.de/vw/thunderbunny/vw-thunder-bunny-02.jpg
darkman
07-01-10, 07:38 PM
:lol: really mike
It may well have a drive chain too.
SkullV
07-01-10, 08:17 PM
:lol: really mike
Oh god, did you save that pic to your computer for future use? Hahah. In any case that does NOT have a timing chain, it has a timing belt. They switched to the timing chain in 2009 and that car is a 2006 IIRC. So HA!
V-Eight
07-01-10, 09:33 PM
Yes, usually pushrods have timing chains and other configurations have timing belts.
heavymetals
07-01-10, 09:36 PM
Or gears (pretty noisy!).
ahahnu
07-01-10, 09:40 PM
I don't know everything (or anything), thanks guys. Will, your time will come.............................................. ...............
814V
07-01-10, 09:46 PM
I assumed it was gear driven. My bad..
concorso
07-01-10, 09:50 PM
Yes, usually pushrods have timing chains and other configurations have timing belts.Is there a reason that the other configurations use belts instead of chains? What reason would GM have for using a chain with the dohc 3.6L. Im not engine expert, but it would seem to me that choosing between the 2 had more to do with durability vs NVH, not the style of engine?
shadybx7
07-01-10, 09:55 PM
"i kid i kid":duck:
ahahnu
07-02-10, 08:24 AM
:highfive: I know, that's the fun part. :Poke:
V-Eight
07-10-10, 01:53 PM
From what I've read belts are better suited for the higher speeds of modern engines (which is a characteristic of DOHC engines). Another reason they are used is because of the ease of implementation which lowers cost.
WesH8398
07-11-10, 11:08 AM
My 97 Mustang was an overhead cam design and it was run off a chain ...
Slithering_Joe
07-12-10, 04:50 PM
My Cobra had 4 chains in it.
NASCAR [pushrod] engines use a belt.
TheSilverMonkey
07-16-10, 01:39 PM
Just out of curiosity, does the NorthStar use a belt or set of chains?
Every DOHC 4 banger (4G63, Hondas) I've worked on in the past has had a belt also inline 6's (2JZ-GTE, for example). I'm sure there are exceptions as I've just worked on mine and friend's cars.
ahahnu
07-16-10, 07:02 PM
This is turning into the prop shaft discussion of yester year. I was watching ultimate factories last night and they were putting together a Z06. They called it a prop shaft.
V-Eight
07-16-10, 10:41 PM
But don't Nascars have a really short stroke so they can rev to like 10k?
Slithering_Joe
07-17-10, 12:26 AM
They use very good parts.
EChas3
07-17-10, 12:40 AM
10K RPM in a NASCAR 348 CID pushrod motor will damage the valve train. N* use chains.
Belts are cheaper, quieter and need frequent replacement.
