: Need a hole
sven914
06-28-10, 04:40 PM
I need a hole that I can push a wire through and have it end up somewhere behind the ECC. I know there is one, as I've heard talk about it, but I haven't seen a post that tells me the actual location. A picture would help greatly, but if someone could tell me the general location, I could probably find it.
The-Dullahan
06-28-10, 08:58 PM
You're trying to run a wire through the firewall, right?
Precisely how big of a wire? and from where on the inside are you running it?
csbuckn
06-28-10, 11:29 PM
This is where mine is. I wanna say its where the vacuum for cruise comes out. Bad pics from my cell but you can see the grommet out of the wall. Right below the brake booster and next to the column.
http://i935.photobucket.com/albums/ad196/csbuckn/IMAG0179-1.jpg
http://i935.photobucket.com/albums/ad196/csbuckn/IMAG0180-1.jpg
The-Dullahan
06-29-10, 12:21 AM
Same hole I used. It has some 0-gauge wire and a few others running through it. It's plenty large.
I ran the wires around to the left (over the parking brake) and beneath the carpet.
sven914
06-29-10, 01:04 AM
Got it, thanks. I thought there was something under the brake booster, but wasn't sure. And Dullahan, the wire is 15 gauge and it just needs to go from the front of the engine to the right side of the climate control.
The-Dullahan
06-29-10, 01:14 AM
Then in that case, that is certainly the best place to run it without making another hole.
Mmmmm Holesaw.
