: threading for norms inserts
06-26-10, 11:46 PM
hey guys, im looking to redo head gaskets and inserts on my 2000 deville. im gunna use norms. can some one show me the correst bolting sequence when tightening the bolts. Guys I need as many poniters as possible. thanks in advance
06-27-10, 01:32 AM
I did Norms inserts as well.
This thread may help you if your using stock GM head bolts:
06-27-10, 11:30 AM
Also check the Tech Tips forum. There are a couple of head gasket tutorial in there that may be helpful to you.
06-30-10, 07:32 AM
go with Jake's studs. I have seen them installed by him. There is no substitute. On a side note, when my head gaskets blew, the studs that pulled out from the block had part of an insert still attached to the bolt.
