: Volume
06-26-10, 09:47 AM
I have an 05 V and this morning had a problem with my radio volume. The volume would only go up so high, but was not as high as I know it will go. I can turn it lower and all the way off, but only up so much.
I did short crank it before I started the car and then started it again. Did I do something to it?
06-26-10, 12:30 PM
If you have it turned on, try turning off the speed controlled volume setting and see if that makes a difference.
06-26-10, 10:21 PM
Well I went and cranked up the car to run to Chipotle and the volume was blaring. I'm now able to control it again and it works like normal. I have no idea what happened to it.
your maker
06-28-10, 01:44 PM
the fix is to clean the contact in the trunk at the amp. the pins sometimes get bent and dont contact the plug correctly
