View Full Version : What's the largest 20" tire I can fit under a 2000 Escalade?
VIPERBLUELX
08-31-04, 12:11 PM
I've got 20" Torque Thrust ST's I'm putting on a 2000 Escalade, what's the largest tires size I can go with? 275/55/20?
Xrayqueen
09-01-04, 05:14 PM
I'm rollin with Goodyear P285 50R 20 and Devinci Havac's rims. No rubbin just lots of looks :D
Peace :bouncy:
DeL2000
09-02-04, 02:31 AM
You could probably use up to 45,check with the tire dealer, they can tell you what's the max for a 20 inch wheel for a Lade. Currently I'm using 275/55/20
:cool:
skides1
09-03-04, 03:11 AM
Viper,
Toyo Proxes has some HUGE tires! I have a friend with 325/50/20's on an Excusion and it is very HUGE![URL=http://http://www.1010tires.com/tire.asp?tirebrand=Toyo&tiremodel=Proxes+S%2FT&pc=242340]
The Pic doesn't do them justice. That size will probably rub. I am going with the 305 45/20's . 285/50/20 matches the fact diameter and are about 12"s wide-they look best on 20x10" wheels-the 325/50/20's will alter your speedo due to the increased height. 325=325mmwide, 50 means 50% sidewall height of 325, 20=rim size. I hope that made sense :D
