View Full Version : Cleaning Suede Wheel & Shiftknob
Razorecko
06-22-10, 10:32 AM
My suede wheel and shift knob have gotten pretty darn dirty and matted over the last 17k miles. I tried a couple ways to clean it and found out the best way to do it was to use regular "Dawn" brand dish soap and microfiber towels. Just lather up the microfiber up with water and soap and than brush into where you are cleaning. ALOT of dirt will lift up to the point that you'll think youre lifting the color off. But you're not. Lather it up really good than use another plain wet microfiber towel and just take the soap off. Than every few minutes just rub it down a little with a dry towel to "fluff" up the fiber. Here are the results...
http://img85.imageshack.us/img85/9747/img0263kb.jpg (http://img85.imageshack.us/i/img0263kb.jpg/)
http://img823.imageshack.us/img823/7551/img0264n.jpg (http://img823.imageshack.us/i/img0264n.jpg/)
SleepTight
06-22-10, 10:45 AM
Awesome advice and result! :worship: Now, what can you do about that oil leak in the Gulf?
Sticky please!
Razorecko
06-22-10, 11:22 AM
Sticky please!
lol, thanks. This suede material is alot more durable than people think and its great to know it can clean up so well.
concorso
06-22-10, 12:36 PM
Personally I wouldnt use Dawn dish soap. Without getting into a big discussion about the PH of Dawn dish soap, Ill just say that I think its just too harsh for the microsuede. Itll clean great as its a detergent, but I fear itll break the the fibre structure, enabling it to 'wear' faster...detergents are very harsh for soft fabrics
Id use a dedicated Alcantara/suede cleaner that foams. Both of these are good products....
http://www.autowerkesexclusive.com/products/Interior/RaceGlaze-Alcantara-Cleaner/index.html
http://www.detailersdomain.com/leathermaster-foamcleanerforsuedeandalcantara.aspx
Razorecko
06-22-10, 01:28 PM
I think the stuff in the caddy is alot hardier than people give it credit for. I cleaned mine at 17k miles, I saw 0 fibers coming off onto the hot pink microfiber towel
nynd
06-22-10, 01:53 PM
Good to know at least there is a good method to cleaning the knob and the wheel. -> You can always dilute the dawn further so hopefully it won't be as strong.
Razorecko
06-22-10, 01:56 PM
Yea it takes a full day usually to dry but today it has that nice brand new look to it where you can just rub the suede and have it "shadow" again
concorso
06-22-10, 03:27 PM
Good to know at least there is a good method to cleaning the knob and the wheel. -> You can always dilute the dawn further so hopefully it won't be as strong.Just keep in mind that you should try not to get sueded materials too wet. Thats why a foam cleaner works so well. It can lift grime without wetting.
Also, dawn is a detergent/soap, and its designed to be flushed with water. This means that if you dont rinse your suede numerous times, you might be leaving residue on the suede, which will attract dirt easier.
Razorecko
06-22-10, 03:29 PM
I think you might be comparing this to bmw style suede. I actually directly rinsed off my shift knob under the sink and it came out perfectly fine :thumbsup: After trying the micro rags on the steering wheel
concorso
06-22-10, 03:38 PM
I think the stuff in the caddy is alot hardier than people give it credit for. I cleaned mine at 17k miles, I saw 0 fibers coming off onto the hot pink microfiber towelI was speaking more to long term results. You could be weakening the structure, yet the fabric might maintain its proper function and look right up until it falls apart, like a rusted brake line that functions ok, but falls apart the instant you touch it.
Heres the way I look at it. You wouldnt use a diesel oil in the engine. I wouldnt use a rinsing cleaner on a surface that cant or shouldnt be rinsed.
Ill make it clear this is just my opinion based on a little research and experience. I am not an expert.
Just my opinion. Id look for a biodegradable APC that doesnt need to be flushed, if youre looking for a local simple effective solution.
Im still skeptical about the long term safety, too...but again, Im no expert.
concorso
06-22-10, 03:40 PM
I think you might be comparing this to bmw style suede. I actually directly rinsed off my shift knob under the sink and it came out perfectly fine :thumbsup: After trying the micro rags on the steering wheelSounds like it worked out well for you! I dont know how the actual fiber differs, but Id assume they are fairly similar as they are both microfiber synthetic suedes. They are made by different companies tho...the V's suede is made in the US, while the BMW's Alcantara is made in either the UK or Japan.
You dont mention it, so Im assuming you never saw any dye transfer?
Razorecko
05-01-12, 08:24 AM
Just to update this thread. I have cleaned my suede on my wheel and shifter again recently ( around 40k miles ) still no dye transfer and it looks great again.
TriTexan
05-01-12, 02:23 PM
I'm assuming all of this discussion will apply to the auto stick with suede as well? I think the brush is sound - that's always been the way to clean sueded shoes, right? So it seems just some personal prefs around choice of cleaners. The foam stuff seems safest, right? But I've found there's never a great substitute for a full rinsing...either way, the pics tell the story. Thanks for posting - I was wondering myself how to keep that stuff clean. The steering wheel feels great, but I figured it would need a lot more TLC than the rugged cowhide on my old car.
dcc8203
05-01-12, 04:58 PM
Somebody should send this thread over to Car and Driver, who complained about the appearance of the shift knob and wheel after their 40K mile test ride!
concorso
05-01-12, 05:16 PM
Just to update this thread. I have cleaned my suede on my wheel and shifter again recently ( around 40k miles ) still no dye transfer and it looks great again.Do you use any type of brush to fluff up the suede, or does cleaning leave it as pictured?
Razorecko
05-01-12, 06:00 PM
no brush. I just used a wet microfiber towel that was lathered in dawn liquid soap ( strips car wax ) and than just use a dry microfiber towel to dry it and brush it up a little and than let it dry. Once you start working on it you'll realize the stuff is not gentle and is really tough
concorso
05-02-12, 10:12 AM
Very very good! Some of the other fauxsuede products are not as durable.
DangFoo
05-02-12, 03:32 PM
This method worked well for me too - thank you. My 2011 was bought used and it looked as if somebody had grabbed the wheel after eating a powdered donut; something was caked into the fibers. Looks like new now.
AmyBeck
04-26-14, 07:27 PM
Thank you, thank you, thank you! I love the suede, but upset because I thought it was wearing out. Followed your instructions just a few minutes ago and it looks like new, just like when I bought it!
RVC
04-26-14, 09:32 PM
My wheel is in great shape for the mileage, but there is an air pocket in one of my spokes. I bought a high quality leather wheel cover custom fit....but the damn thing does not fit right and they do not allow returns. I am pretty pissed.
Sent from AutoGuide.com Free App (http://www.autoguide.com/mobile)
datadawg
04-28-14, 12:23 AM
I don't like the suede at all. Makes me think of fuzz on tennis balls. And I bet the sweat from your palms makes it stink too. I hunted and hunted and via some miracle found a Vagon w/o it. Seems like 90% of all Vagons have alcantera wheel.
mot76
09-02-15, 09:32 AM
I own a 2012 CTS coupe with the touring package. The suede on the steering wheel is looking faded. Could I use shoe dye designed for suede on it? Also, what color would I use; black or dark gray? To be honest, I haven't clean it yet because I recently bought it. Could the faded look be embedded dirt? Thanks for any advice.
tinman
09-02-15, 12:18 PM
First try a mild soap or Sonax. Or actually, use just a moist microfiber towel, and if that doesn't clean it then go to the mild soap or Sonax treatment.
After cleaning you can inspect to determine if it is faded (which I don't think it is fading).
vfaninva
09-02-15, 12:51 PM
Never heard of fading being an issue with the alcantara wrapped steering wheel and shifter. My '09 didn't have any fading.
You do know it's supposed to be gray, right?
Anyways, follow tinman's advice and your wheel will look good as new. :)
mot76
09-02-15, 01:44 PM
Tinman, I tried cleaning it with a damp microfiber towel, since I don't have any Sonax. OMG! The dirt that came off was unbelievable. The rag was black. The previous owner must have driven with very dirty hands. lol
It looks a lot better now. Thanks for the tip!
tinman
09-02-15, 01:51 PM
Excellent.
I actually use driving gloves just because of that. Yeah, they look gay, but screw it, it preserves the alcantara.
stupidfast
09-02-15, 02:19 PM
I don't think your allowed to use "Gay" like that anymore, at least that's what they keep telling me.
tinman
09-02-15, 02:42 PM
Courtesy of Merriman-Webster:
"Full Definition of GAY
1 a : happily excited : merry <in a gay mood>
b : keenly alive and exuberant : having or inducing high spirits <a bird's gay spring song>
2 a : bright, lively <gay sunny meadows>
b : brilliant in color
3 : given to social pleasures; also : licentious
