View Full Version : 05 cts v rear axle
splitfire66
06-22-10, 10:16 AM
i am working on a 05 cts v with a severley damaged rear diff. i have found a 06 srx diff with the proper ratio and posi but is it the same as a cts diff
ctsv154
06-22-10, 10:46 AM
Yes. You may have to change the pinion out because the standard cts ans srx diff have a different one than the V but other than that, you should be good. Ifnim not mistaken you can cut the drive shaft centering pin off the pinion on the srx and bolt the cv style yolk to the srx pinion.
