: 1998 Deville: go with Arnott, Suncore, Monroe air ride shock?
06-20-10, 11:21 PM
My left rear shock leaks a little. Compressor cycles fine and both shocks pump up (trunk test), but as soon as the cycle stops a small hissing sound from left strut 4 minutes compressor kicks on. Soooo
I'm going to replace with either Arnott, Suncore, or Monroe. I can get Monroe from Advance Auto slightly less $$ than Arnott. Suncore is about $40 less than Arnott. With money not an option, What system would you go with?
I lean to Monroe, only because of the big long lasting name. Input? , But like the total setup of Arnott.
06-21-10, 06:50 PM
what is the trunk test you are referring to??????????
06-21-10, 08:53 PM
With trunk door open, setting on the edge and alowing the compressor to kick in to level the rear end. It does that and a small hissing sound from the drivers side wheel well. Ordered Arnott's today. I'll get back when I have time to install in a few weeks....
Mistake on the Monroe's from Advance Auto, they are OEM and $430 each..... couldn't see spending $860..
07-18-10, 09:11 PM
Update. The Arnott air will work fine. My '98 Deville doesn't have the eletronic solanoid on each shock.
