: o2 sensor?
06-19-10, 01:29 AM
Is there an O2 sensor on a 1987 Brougham with the 307?
If so where? I cannot find it!
06-19-10, 02:06 AM
pass side on the exhaust manifold right before it connects to the exhaust pipe. Just did one on an 88 from the top.
06-19-10, 03:00 AM
If you look in the back passenger side of the engine, you can see the electrical connector going to it. They're not hard to reach but are a bitch to get out. You need a special O2 sensor socket to remove and install it (properly) but if you cut the wire you can use a deep well to get it off and then hand tighten it.
06-19-10, 09:16 AM
Thanks guys,
I rented the tool but there is way too much stuff under the hood. I am used to 1980's volvos and sciroccos!:)
06-19-10, 11:42 AM
It was done and easy with lots of extensions and a u-joint
06-19-10, 10:50 PM
I did mine a few years ago, but from what I remember I think I just unplugged the last two passenger side spark plugs and put them aside so I could gain some access to the o2 sensor down there.
I don't remember much from that, but it shouldn't be too hard to replace it.
06-21-10, 12:26 AM
It was a pain for me. I had to use a cheater bar moving it one click at a time.
06-21-10, 08:52 AM
I used the u-joint on the O2 socket and from there I used the extensions so the ratchet would be above the engine. It worked perfectly, 5 min it was changed.
06-21-10, 09:36 AM
Go in through the wheel well, there is a rubber apron to move out of the way, but still a better angle. I was able to use a wrench.
06-21-10, 01:48 PM
Cheater sticks and extensions? How do you guys fit that down there? I could barely get in there with a 3/8 drive ratchet and the socket.
06-21-10, 02:03 PM
As I said I did use a "u-joint) (if that is the term), to change the angle of the extension. The u-joint I installed right on the O2 sensor tool
06-21-10, 02:36 PM
^They're called swivel sockets or universal joints, either one is correct. I don't have any and don't remember ever using one.
