: Windshield Washer Pump
HUF
06-18-10, 09:18 PM
Something kills my washer pumps. Two pumps in six months... What could be the culprit? Thanks.
csbuckn
06-18-10, 09:36 PM
Maybe a bad ground?
HUF
06-19-10, 12:38 PM
Maybe a bad ground?
Nope. Checked the voltage at the connector and it was fine. Applied voltage to the pump from another source and it worked... Reconnected/disconnected the connector three times - nothing changed. Only after some ten reconnections everything was back to normal. Tested the old pump and it appeared to be fine as well. The lesson learned. Do not try to refresh connections by reconnecting two-three times. It may take more than that!
