View Full Version : Fluids
rbu1
06-14-10, 04:17 PM
OK so I am about to hit 50k on the odometer. I am going to have my mechanic start changing out fluids. First up is the tranny.....Then the transfer case. What other fluids should I change? and what types of fluids?
Thanks for the help.
evois
06-14-10, 05:01 PM
it should be in the OM. you can download it from the cadillac website.
07maralade
06-14-10, 06:40 PM
Diffs
rbu1
06-14-10, 10:26 PM
Does anyone know off the top of their heads the fluid types for each? To save me the trouble of having to find it all. I would greatly appreciate it.
Tranny
Transfer case
differentials
anything else???? Does everything have a drain plug?????
Braknglases07
06-14-10, 11:52 PM
Transmission is Dextron VI
Front diff is synthetic 75w-90
transfercase is either Dextron VI or manual trans fluid with slip additive depending on year mine is 07 and it took the manual 08 and up take Dextron VI
rear diff is synthetic 75w-90
I used royal purple in my front and rear diff, only because they didnt have mobil one syn, so they gave it to me at the same price.
hcvone
06-15-10, 06:22 AM
Amsoil, Red Line or Royal Purple all rated the best, Mobil 1 rated very good, you can find these at many auto stores and speed shops. :)
rbu1
06-15-10, 09:08 AM
Awesome thank you... mine is an 07 does it matter if I use the Dextron vs manual trans fluid? will the manual tell me?
SouthernCaddy
06-15-10, 05:26 PM
Yes I recommend the factory fluids. here is what you need I just did mine.
Transfer case Holds 1.5 quarts GM Part No. 12378508
Front and Rear Axle: SAE 75W-90 Synthetic Axle Lubricant (GM Part No. U.S. 89021677) Front held 2 quarts the rear held 2.5 quarts.
The Trans uses Dexron 6, I am going to let the dealer flush mine so I did not do this one.
Hope this helps. I know other oil companys make there own oils and people swear by them. I am a Moblie 1 die hard user, but I figure for my Caddy why not use the factory oils for it? yes I use Mobile one in the engine but for the brakes, oil filters, air filters, Plugs, fluids....ect it is all GM!!!
rbu1
06-15-10, 07:43 PM
Thanks SouthernCaddy....I appreciate the help
Braknglases07
06-15-10, 08:59 PM
If you have the 07 like me use the manual transmission fluid, i would not use the dextron, The manual says to use Manual trans with slip additive
hcvone
06-16-10, 06:09 AM
The 2007 service manual calls for Dexron VI only
rbu1
06-16-10, 09:43 PM
In the transfer case?????
because thats what he was referring to.
rbu1
06-16-10, 09:45 PM
We did the transmission filter change and flushed the system with the dex VI. I will do the rest of the fluids shortly.
