: 255/40/18 up front? anyone running this tire
RADARB8
06-12-10, 06:21 AM
I probably will be putting 295/35/18's on the rear with my 10 3/8" widened stock rims... seems like every tire i check for the front in a 245 is a 93 load capacity....I did a search but found nothing..I wouldn't mind running a 255 but i looked under there and wow..not much room..:bouncy: has anyone tried to run a 255 up front and if it works, what brand tire are u using. thanks Greg:alchi:
RADARB8
06-12-10, 06:30 AM
btw i found this post back in 2006. This is all i could find...Also i do have the upgraded optional shocks with Eibach's..The raason for the 255's are for the 96+ load capacity campared to 93 and also the height for rear and front would be only 1/10th smaller in dia. in the front........
03-27-06, 03:07 PM
Parker
Cadillac Owners Enthusiast
Casino Cash: $415
Re: Eibach & 255's in the front???
My 255s don't rub at all with the Eibachs!!!
Twitch
06-12-10, 06:33 AM
I'm running 255/40 18 all around. I'm lowered a bit with no rubbing.
Don't know if it's the early hour or age, but I can't remember the name of my tires,,,,,,,,GOT IT, Falkens :duh:
RADARB8
06-12-10, 06:52 AM
It is early:D thanks for the response....I will check with tire rack and look for the dimentions of the Falkens...:cloud9: u can now go back to sleep LOL
RADARB8
06-12-10, 08:11 AM
When u awaken, could u tell me the type or name of the Falkens u are running
. thanks Greg
Twitch
06-12-10, 11:30 AM
. thanks Greg
RT-615
Tire rack doesn't sell them. Got em from vulcantire.com
MauiV
06-12-10, 08:18 PM
I used to have 275/40s on all 4 corners with no rub.
AG'S-V
06-12-10, 08:23 PM
What about 255/45s? Will they rub up front?
darkman
06-12-10, 08:27 PM
I am running 255/45s all the around, stock height no issues.
kirchbed
06-12-10, 08:33 PM
Had Toyo Proxes in 255/45 in front, no rubbing (including track).
ronr
06-12-10, 09:21 PM
I've got 255 40 18 Falken RT-615 on all corners. Lowered with GC coil overs. Just a very slight rub first time I took it to the track and no problem since.
Jasonv8z
06-13-10, 05:20 AM
Just got new 255/40/18 Hankook Ventus V12's on all 4 corners. No problems. Great tire.
ahahnu
06-13-10, 02:39 PM
255/40/18 Faulken 615s no rubbing. the 245/45/18 winter Hankooks rub. I measure 13 1/8" from center of hub to lip of fender.
RADARB8
06-13-10, 05:28 PM
WOW, got some great responses...i looked at my 245 Perilli's and it seems awfully tight....now i can do some serious shopping for matched front and rears. I already have a brand new set of proxes for the rear so i might go with the 255's up front...:alchi: thanks guys for the info.:thumbsup:
RADARB8
06-13-10, 07:51 PM
do u know if u have the Proxes 4- 99W or the Proxes t1r- 99y ??the Proxes4 is 1/10" wider and it is sooo close it might make a difference.:banghead:thanks Greg
kirchbed
06-14-10, 02:21 AM
I had the T1R's. Fine tire. Expected the high dry performance; really surprised by exceptional wet performance.
RADARB8
06-14-10, 05:00 PM
:thumbsup:Thanks kirchbed, i have the upgraded GM shocks with Eibachs but that should not have anything to do with the width of the tire..thanks for the comeback Greg:)
