: Reluctor wheel clocking?
06-08-10, 10:33 PM
I have a 2005 Northstar engine and since no one supports this engine I am having to swap over to the 2006 electronics. One of the items I need to use is a 58x reluctor wheel which apparently is not swappable in the Northstar so I will bolting one to the crankshaft pulley. So, I need to know where to clock the sensor on the wheel. Does anyone know a reference point I could use? I figure it will be something along the lines of X amount of teeth pass the gap for piston 1 at TDC.
06-18-10, 08:00 PM
#1 you can purchase a box to convert a 24x to 1 58X
#2 Do you need the location of your 2005 crank sensorS or the location of the 2006+ crank sensor?
