: Reinstalling window motor and fixing other equipment.
antoonio
06-07-10, 07:37 AM
Hey
As i had a annoying problem with wintow motor and i ope i finalyy fixed it (reason was simple "brushes" was completely dead) i have problem reinstalling all the stuff. Ok. putting motor back is not a problem but fixing other stuff makes me disapointed.
Take a look on this pic
http://www.hot.ee/sniff01/Caddy/uksseest.jpg
These red circles shows 5 places which i need to fix put both side holes on the same place that is big problem. Things looks like this, if i fix on hole then other 4 is not at the same place. What kind tricks i should to do :hmm:
Car is Coupe Deville 79.
deVille33
06-07-10, 08:24 AM
I have to ask. How did you remove the rivets?
antoonio
06-07-10, 09:10 AM
easiest way i think, i just drilled them out. Now i am going to use short bolts.
deVille33
06-08-10, 08:43 AM
Use longer bolts to temporarily mount the mechanizm to the door. Use a pin punch to help align the holes. Ensure there are no burrs on the holes to prevent installation.
antoonio
06-08-10, 09:15 AM
I will:) and i know that. Also i have to one very tricky work to do.
Anyways, there is a pic how was a look of this motor which made me realy sick.
http://www.hot.ee/sniff01/Caddy/mootoruks1.JPG
deVille33
06-08-10, 09:35 AM
Bet your window seals are bad and allowing water to get inside.
antoonio
06-09-10, 02:37 AM
Yea, you can be right, but this motor has also 30 years so anyway brusesh need to replaced one day.
But, now i can say, DONE:D
Hopefully it will work long time now and need to say that i got one weird thing. If i switch on ingition then central lock will close the doors and when i switch off then lock working again and "open" the doors. :hmm:
deVille33
06-09-10, 08:36 AM
In later cars that was an option for people with children. Didn't know it was available as early as '79.
antoonio
06-09-10, 09:05 AM
This is bit weird cos normally central lock worked only after putting gearbox onto Drive mode.
