: Escalade ESV running rich
Muskie
06-03-10, 08:39 AM
I have a 2007 Escalade ESV that is exibiting all the tells of an engine runnning a bit rich. Black sooty exhaust, smell of exhaust, feels a bit down on power and MPG in the tank (of course it is an Escalade). One more thing, under acceleration it feels like it surges a little.
Is this a common issue, fuel injectors dirty? Any thoughts are appreciated.
hcvone
06-03-10, 09:41 AM
How many miles? How is the air filter? Ever used any fuel injector cleaner in your tank? May have a dirty t-body or just need a tune up. What grade of fuel do you use?
07maralade
06-03-10, 12:08 PM
do you have a vibration at idle? How many miles? Check the air filter, run some chevron fuel injector cleaner.
Cadillac Cust Svc
06-04-10, 10:56 AM
I would suggest having the vehicle checked by a dealership just to make sure that there isn't something actually wrong with the vehicle. You should still have the 5 year 100,000 mile powertrain warranty which would cover this kind of a fix for your vehicle. I hope that solves your issue.
Jeff Morris, Cadillac Customer Service
Muskie
06-05-10, 07:26 PM
46k, air filter is brand new and changed regularly. I have not dumped FI cleaner in the tank as yet. Tune up is not out of the question.
Muskie
06-05-10, 07:28 PM
It does seem to have a bit of a stuble at idle. More than I would expect. As i mentioned it also seems to surge or accel unevenly. Air filter is brand new and I will look into fuel injector cleaner.
Thanks!
Muskie
06-05-10, 07:33 PM
Thanks Jeff,
Probably not a bad idea. I do plan on taking it to a dealership to check it out. I just want to have some idea of whether or not this is common to these vehicles at 45k. Car has been bullet-proof otherwise!
hcvone
06-06-10, 06:56 AM
I would tune it or have it tuned up, fuel injectors could use a cleaning for sure, t-body maybe dirty and you would want to check or have someone check the wires too, at 46k miles it's not too soon. :)
Muskie
06-06-10, 06:34 PM
Thanks for you suggestions. I have a pretty good idea of how to address the issue now.
Muskie
06-11-10, 11:15 AM
If anyone cares:
It did turn out to be a very dirty throttle body. The dealership also had to "re-learn idle". They also "reprogrammed the ECM with latest updates"
...Oh...and it was all covered under the powertrain warranty.
That is why these forums are so useful!
07maralade
06-12-10, 11:33 AM
Powertrain?? Are you sure it wasn't bumper to bumper?
