View Full Version : Trans fluid change yeah or na
chitownv
05-31-10, 12:31 AM
I have a 2006 with 48k on it I recently bought it so I am unsure of previous drivers driving habits hard or soft.
Should I do a complete trans flush ? I want to so I don't have to worry about it but scared new trans fluid will cause problems
Has any one changed trans fluid in there v with no issues ?
550HP STSV
05-31-10, 11:46 AM
i just changed mine last weekend with amsoil fluid, a new filter, and amsoil flush. Be aware you need a shop that has a flushing machine to do it, and they will need an STS specific attachment to do it. The gasket around the trans pan is reusable.
chitownv
06-02-10, 06:18 PM
Thats for the reply just curious how many miles do you have on your v and what year is it when you flushed the trans fluid ?
Also did you notice any difference ?
C66 Racing
06-05-10, 09:58 AM
I'm a big believer in early fluid changes for both the tranny and the diff. Though not an STS-V, here are the fluid samples I submitted in my 06 CTS-V tranny and diff showing the stock tranny fluid had sheared low out of grade in only about 10k miles and the diff was showing excessive wear:
2006 Cadillac CTS-V Used Oil Analysis Factory Fill Differential Fluid (http://www.c66racing-synthetics.com/TestResults/CTS-V%20Differential%20UOA.htm)
2006 Cadillac CTS-V Used Oil Analysis Dexron III vs AMSOIL ATF Transmission Fluid (http://www.c66racing-synthetics.com/TestResults/CTS-V%20Transmission%20UOA.htm)
FYI, this is the fluid AMSOIL recommends for your tranny (not the same ATF that mine took):
AMSOIL Low Viscosity Universal Automatic Transmission Fluid (ATL) (http://www.c66racing-synthetics.com/Product%20Bulletins/ATLPB.htm) (Product Code ATLQT)
:cheers:
550HP STSV
06-06-10, 11:27 AM
I swapped all fluids - oil, trans, coolant, diff.
I have 50k miles, and I thought I needed a new transmisison it was shifting so hard. I did the AMSOil flush, trans filter replacement, and amsoil fluid. Now my trans feels like brand new. Glad i took a chance with a flush before I dropped $1500 on a new trans install!
chitownv
06-06-10, 12:01 PM
Is amsoil the fluid the dealer uses ?
550HP STSV
06-06-10, 12:29 PM
no. amsoil is a superior product. PM me for more details.
