View Full Version : 98 Catera heater help
Rcombs
08-27-04, 02:59 PM
I dont have time to change my leaking heater coil (or the money) so I am planning on diconnecting the pump that runs water thru the coil, but I think that there is also a heater element that needs to be disconnected. Am I correct, and does anyone know an easy way to do that, a fuse maybe?
Thanks in advance.
Vesicant
09-05-04, 07:20 PM
The heat in a car works by hot coolant, nothing electric (except for the valve control)
D.Boy
10-26-04, 11:55 AM
I kinda have a heater problem as well.When i turn on my heat one side blows hot, the other blows cold and the back also blows cold. How do i fix this both sides are tuned to the same degrees.
mastertech
10-27-04, 01:06 PM
check your coolant level first, if low, add correct amount and then check for leaks....water control valve, or oil cooler if you are less fortunate.
