: Gapless Piston Rings
Loose screw
05-21-10, 09:44 AM
I bought a 99 STS with 120 miles with a leaking head gasket. I ordered the stainless head gaskets and am currently doing the stud conversion (not cheap). The Cylinders look great as do the rings but as I am in there and spending this kind of money I want to replace the rings and of course the rod bearings. But having searched the messages I can not find much about GAP-LESS piston rings on N* engines or specific parts recommended.
Are Gap-less rings recommended? If so or not, could you please supply Part numbers and source and why you recommend the rings you do.
I also need the same for Rod Bearings and new Rod Bolts.
Having spun a rod bearing in another N* engine I want to make sure I install only the best.
Please - part numbers, source and why. Thank you
Submariner409
05-21-10, 10:14 AM
Call the guys at www.chrfab.com
But look at their disclaimer down under the engine picture: You're looking for engine parts which do not exist. At 120,000 you never should have disassembled the lower end unless the oil pan or halfcase seals were leaking badly.
For all parts other than the head gaskets and Jake's studs, use the most common online GM/Cadillac references in here and Seville.
Ranger
05-21-10, 12:23 PM
Are you saying that you already pulled the pistons? If so, that's too bad. Lower end never needs work.
What's a gapless ring? How do you install it?
Submariner409
05-21-10, 03:46 PM
"Gapless" rings have an overlap, or step, at the gap - they aren't "gapless" per se - they are supposed to have less low speed leakdown, but the OP doesn't realize that the Northstar uses special low-tension rings with a computer-controlled cylinder hone and leakdown is not a problem. The cylinder pattern should be visible after over 200,000 miles: it's also an oil control crosshatch design. The only change is that 2003+ replacement pistons use a coated skirt to minimize scuffing from the newer oils with less ZDDP. Also, the crank uses special journal fillets, and the GM service manual cautions not to grind the crank - replace it if the journal specs fall outside the .002" undersize bearing replacement.
He posted that he wanted part numbers and sources, so advice appears useless.
Loose screw
05-21-10, 09:29 PM
Yes pistons pulled. The last N* I worked on a 94 concourse I was glade I pulled the pistons, the rings were seriously worn due to oil starvation but the cylinders looked great but the engine still ran well and was not burning oil which could have changed soon.
allot of discussion here about Gap-less rings but I didn't see anything specific about use in Northstars: http://www.speedtalk.com/forum/viewtopic.php?f=1&t=18568
Ranger
05-21-10, 09:38 PM
That's rare.
tateos
05-21-10, 11:59 PM
Loose screw:
All really good info Ranger and Sub - they are telling you straight.
Nevertheless, you are going to do what you want to do, and we wish you well.
