: Can I lower the rear 1"?
Red Snake
05-17-10, 09:25 AM
Are there any options to just lower the rear end about 1"?
I do NOT want to install a full lowering kit. I don't want to touch the front end. I just want to lower the rear down about 1 inch to level the car up a bit. Any options for that set up? Would that require spring replacement?
05-17-10, 04:31 PM
No because it will just raise itself again. There was a kit running around to "Trick" the car so lowering springs would stay at the lowered level. Don't know if you could just use the spacers without the lowering springs.
05-17-10, 06:27 PM
no lowering with the stock Nivomats....put another shock in there and your a-o-k.
