View Full Version : 3.6L: Stumble/lag on initial throttle tip-in
schnack
05-17-10, 07:42 AM
I started to notice an intermittent stumble, lag on initial accleration (throttle tip-in) in 6th gear 2 weeks ago. Now it has occurred in at least one other gear, here's some maintainence history:
2005, 3.6L 6 speed, 78k miles
-Replaced under warranty at 49,700 miles: Timing chains, clutch and shift linkage bushings, driveshaft
-Cadillac serviced at 71k, Fuel injector system cleaned due to 2,4,6 misfire.
replaced by self, air filter
Next steps i'm considering - flush diff, trans. fluid., have dealer re-check for misfire(s).
Any suggestions?
Spyke
05-26-10, 05:54 AM
have you clean the maf sensor yet?
briggy
07-13-10, 07:04 PM
are you getting any codes ?
webbnr432
09-06-10, 05:13 PM
having same problem on my 2005 3.6 with 79k aswell mine is an automatic n e suggestions on where to start to look for the problem??
gterrell
11-30-10, 02:30 PM
I'm having a similar issue with my 2005 CTS, 3.6. I had a misfire on cylinder 2, changed all plugs and cleared codes. The engine runs great under load but stumbles intermittently at idle and has no fault codes. I can't hear any whistling or sucking noises as if the intake manifold were leaking BUT since the problem occurred after having to remove it I have to assume it's that or a vacuum line. What all should I check before taking it to a shop?
gterrell
12-01-10, 11:15 AM
I cleaned the MAF sensor as mentioned above....problem solved.
