View Full Version : Tow/Haul Button
rodcole1
08-26-04, 04:32 PM
Does anyone know if you can reprogram the computer changes that are made when you push in the Tow/Haul Button ??
I'm thinking that would be great to have a quick way to tweak the computer system at a touch of a button for instant performance when needed.
Thanks.
hcvone
08-30-04, 09:08 AM
If you get your computer reprogrammed the tow/haul mode is like a performance button, it changes your shift speeds as well as other engine funtions
rodcole1
08-30-04, 05:50 PM
How do I go about programming just the tow/haul button ??
T_Dogg8
08-31-04, 08:14 AM
i would guess there's a wire you can tap into and install nitrous. that would probably be the easiest wat to do it. as far as changing the whole computer to have like a performance side and regular side, i'm not sure you can do that.
Gvit
09-02-04, 11:01 PM
Purchase a Diablo Predator. You can adjust trans shift points, pressure, etc that take effect only when you push the Tow/Haul button.
I've got one for my EXT, worth the $$.
