: Engine removal - can't get engine separated from transmission
KHE
05-13-10, 08:58 AM
I am unable to get the engine separated from the trans. on a '97 STS - I haven't had this problem in the past. Before, I just lifted the engine slightly with an engine hoist and jiggled it sideways and it separated. I removed the front motor mount to see if that would help but it didn't. There's no good place to pry either. Does anyone have any tips or tricks? I sprayed penetrating oil along the seam last night to see if that would help. Thanks!
tateos
05-13-10, 02:51 PM
I had this problem too...and I was the problem. Stupid me, I thought the flywheel was held onto the torque converter with 3 bolts, like I have always seen before. Nope - it's 4 bolts! Not sure if that is your problem, but I mention it, just in case.
KHE
05-13-10, 04:23 PM
Nope - I removed 4 bolts from the flywheel. I have never had one that was so stubborn. Even though I followed the service manual steps to the letter, I'm going to check to see if I missed a bracket underneath. It just seems too locked together to be corrosion in the dowels.
KHE
05-14-10, 12:39 AM
The engine is out! The problem was a bolt fastening the passenger rear engine to transmission support. Once that was removed, the engine separated from the trans. without incident.
bigds01
05-16-10, 02:35 PM
Where is that support? How did you get the oil cooler line off the back of the transmission?
cl1986
05-17-10, 01:19 AM
LOL, that line didnt come off either of my trannies, i tried on one but it started to buckle so i quit. You have to rotate the line along with the wrech i believe, not sure why its so stubborn
KHE
05-18-10, 01:22 PM
The bracket was from the rear head to the transaxle. One bolt at the top. I missed it when I disconnected everything and it kept the engine from separating from the transaxle.
I removed the engine from the topside so I did not need to mess with the line in question on the transaxle.
