View Full Version : CD Player Will Not Eject
surburban99
05-11-10, 08:40 PM
Hi,
I have a 2008 ESV, with factory navigation, and the six disc player.
Bought the ESV new in January 2009. Used the CD player only a couple of times. Mostly listen to XM.
Put my new BoDeans CD into the player. This is a factory made CD, not a burned one. Played it a couple of times, now it will not play, nor can I eject the CD.
Any suggestions??
Big Windy Ext
05-12-10, 07:38 AM
:banghead::blasted::party:I have had that happen in the summer with dvds ,the next day and since not a problem . Overheated ??
Alien
05-12-10, 10:20 AM
Try pulling the fuse for a few minutes...
dixit
05-12-10, 02:09 PM
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dixit
Neoex
05-12-10, 06:00 PM
had this happen, i unplugged the radio harness and plugged it back in(requires removing the stereo obviously but that takes all of 5 minutes) and it spit the disc out
hcvone
05-12-10, 06:10 PM
It happened to my 2003, I disconnected the battery for 5 minutes and it ejected, make sure your sound system and HVAC are turned off before disconnecting the battery.
steve841
05-12-10, 07:00 PM
I saw something mentioned on the GM site about a software update to address that or a similar problem....
surburban99
06-09-10, 03:11 PM
Took my '08 ESV to the dealer. They tried to reprogram the CD player with the updated software. Did not work.
The dealer ordered a replacement unit, I thought it would be just the CD player. It comes as entire unit including the navigation, radio, etc.
Replaced under warranty (whew), the whole unit was a couple of thousand dollars. Works fine now.
Hi,
Any suggestions??
Big Windy Ext
06-09-10, 10:39 PM
I better use my player more before the warranty is up.
ewill3rd
06-10-10, 06:56 AM
There is a software update to address this issue for some model years.
The radio memory has to be reset first.
I have had mixed results, some make it, some don't.
Yes it is part of the entire nav/radio which will have to be replaced if it does not recover.
Mr ESV
04-02-11, 12:36 PM
I tried pulling the fuse for 10 min and putting it back but that didn't work for me. Now I can't even push the DISC button on the screen. Any other suggestions?
Playdrv4me
04-03-11, 04:27 AM
Try completely disconnecting the radio from the rear connections for 10 minutes or so. If that fails, your player is fried.
Mr ESV
04-04-11, 08:08 PM
I'll try that tonight and let you know what happens...thx Play. You wouldn't happen to have a service manual on digits would you? Or know where the clips are located on the panel so i can access the CD changer?
rhdune16
02-24-12, 08:57 AM
This just happened on our 08 esv. While listening to a cd, it suddenly stopped working. Then we tried ejecting which didn't work and also tried loading to a different CD which didn't work. Then we tried loading a new cd into a new slot and that didn't work. We just had the unit replaced from a theft claim a few months back and our normal factory warranty is up. Any suggestions fellas?
