BeelzeBob
08-26-04, 11:11 AM
Cadillac Escalade 2WD and AWD
Body style / driveline:
full-size, 4-door luxury sport utility, front-engine, 2-wheel-drive and all-wheel-drive versions
Construction:
all-welded, fully-boxed, ladder-type channel design, with hydroformed front and rear sections
EPA vehicle class:
Manufacturing location:
Arlington, Texas
Key competitors:
Lincoln Navigator, Lexus LX 470, Mercedes-Benz M-Class, Infiniti QX56
Engines
AWD 2WD
Type:
Vortec H.O. 6000 6.0L V-8 (LQ9)
Vortec 5300 5.3L V-8 (LM7)
{midyear change to Vortec H.O. 6000 6.0L V-8 (LQ9)}
Displacement (cu in / cc):
364 / 5967
325 / 5328
Bore & stroke (in / mm):
4 x 3.62 / 101.6 x 92
3.78 x 3.62 / 96.01 x 92
Block material:
cast iron
cast iron
Cylinder head material:
cast aluminum
cast aluminum
Valvetrain:
OHV, 2 valves per cylinder
Ignition system:
coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires
Fuel delivery:
sequential fuel injection
Compression ratio:
10:1
9.5:1
Horsepower (hp / kw @ rpm):
345 / 257 @ 5200
295 / 220 @ 5200
Torque (lb-ft / Nm @ rpm):
380 / 515 @ 4000
335 / 454 @ 4000
Recommended fuel:
premium recommended but not required
regular unleaded, 87-octane minimum
Maximum engine speed (rpm):
5600
5600
Emissions controls:
3-way low-density catalytic converter, exhaust gas recirculation, positive crankcase ventilation, evaporative collection system
Estimated fuel economy:
MPG (city / hwy / combined)
13 / 17 / 15
14 / 18 / 16
MPIG (city / hwy / combined)
14 / 19 / 16
L/100km (city / hwy / combined)
19.9 / 14.8 / 17.6
Transmissions
AWD 2WD
Type:
Hydra-Matic 4L60-E
4-speed heavy-duty electronic automatic
Hydra-Matic 4L60-E
4-speed electronic automatic
Gear ratios (:1):
First:
3.06
Second:
1.63
Third:
1.00
Fourth:
0.70
Reverse:
2.29
Final drive ratio:
3.73
Chassis/Suspension
Front:
independent with torsion bars, 32-mm stabilizer bar
Rear:
5-link with coil springs, 32-mm stabilizer bar
Traction control:
all-speed traction control
Steering type:
power recirculating ball
Steering ratio:
12.7:1
Steering wheel turns, lock-to-lock:
3
Turning circle, curb-to-curb
(ft / m):
39.3 / 11.9
Brakes
Type:
4-wheel ABS; AWD: Hydroboost
Rotor diameter x thickness
(in / mm):
front: 12.01 x 1.14 / 305 x 29
rear: 13 x 1.18 / 330 x 30
Wheels/Tires
Wheel size and type:
17-inch x 7-inch
Tires:
P265/70R17 all-season Goodyear steel-belted radials
Dimensions
Exterior
Wheelbase (in / mm):
116 / 2946
Overall length (in / mm):
198.9 / 5052
Overall width (in / mm):
78.9 / 2004
Overall height (in / mm):
74.2 / 1885
Track (in / mm):
front: 65 / 1651
rear: 66 / 1676
Minimum ground clearance (in / mm):
10.7 / 272
Step-in height (in / mm):
30 / 762
Curb weight (lb / kg):
2WD: 5341 / 2422
AWD: 5554 / 2519
Weight distribution
(% front / rear):
52 / 48
Interior Middle
Rear
Front
Seating capacity:
2 or 3
3
Head room (in / mm):
41 / 1034
39 / 1001
37 / 950
Leg room (in / mm):
41 / 1049
39 / 980
27 / 693
Shoulder room (in / mm):
65 / 1656
65 / 1653
64 / 1636
Hip room (in / mm):
61 / 1560
61 / 1557
49 / 1250
Capacities
EPA interior volume
(cu ft / L):
138 / 3919
Cargo volume (cu ft / L):
64 / 1801 (rear seat removed)
105 / 3064 (maximum w/ 2nd row seat down)
Trailer towing maximum (lb / kg):
2WD: 7400 / 3357
AWD: 8100 / 3674
Fuel tank (gal / L):
31 / 117
Engine oil (qt / L):
6 / 5.6
Cooling system (qt / L):
Payload (lb / kg):
2WD: 13.4 / 12.72
AWD: 14.8 / 14
2WD: 1459 / 662
AWD: 1446 / 656
Construction:
EPA vehicle class:
Arlington, Texas
Key competitors:
Engines
AWD 2WD
Type:
364 / 5967
325 / 5328
Block material:
cast iron
cast iron
cast aluminum
cast aluminum
Valvetrain:
Ignition system:
Fuel delivery:
Compression ratio:
10:1
9.5:1
345 / 257 @ 5200
295 / 220 @ 5200
380 / 515 @ 4000
335 / 454 @ 4000
Recommended fuel:
5600
5600
Emissions controls:
13 / 17 / 15
14 / 18 / 16
14 / 19 / 16
19.9 / 14.8 / 17.6
Transmissions
AWD 2WD
Type:
Hydra-Matic 4L60-E
Hydra-Matic 4L60-E
Gear ratios (:1):
First:
3.06
Second:
1.63
Third:
1.00
Fourth:
0.70
Reverse:
2.29
Final drive ratio:
3.73
Chassis/Suspension
Front:
Rear:
Traction control:
Steering type:
Steering ratio:
12.7:1
3
(ft / m):
39.3 / 11.9
Brakes
Type:
(in / mm):
Wheels/Tires
17-inch x 7-inch
Tires:
Dimensions
Exterior
116 / 2946
198.9 / 5052
78.9 / 2004
74.2 / 1885
Track (in / mm):
front: 65 / 1651
rear: 66 / 1676
10.7 / 272
30 / 762
2WD: 5341 / 2422
AWD: 5554 / 2519
Weight distribution
(% front / rear):
52 / 48
Interior Middle
Rear
Front
Seating capacity:
2 or 3
3
41 / 1034
39 / 1001
37 / 950
Leg room (in / mm):
41 / 1049
39 / 980
27 / 693
65 / 1656
65 / 1653
64 / 1636
Hip room (in / mm):
61 / 1560
61 / 1557
49 / 1250
Capacities
EPA interior volume
(cu ft / L):
138 / 3919
2WD: 7400 / 3357
AWD: 8100 / 3674
31 / 117
6 / 5.6
Payload (lb / kg):
2WD: 13.4 / 12.72
AWD: 14.8 / 14
2WD: 1459 / 662
AWD: 1446 / 656
