: Olds 307 Trouble
05-11-10, 03:58 PM
I bought an 84 Delta 88 with a 307 a few months ago so I could give my Caddy a break and was wondering if anyone could point me in a direction. It was fine until a long trip. First when it is cold it will conk when I put it in reverse after start up. Secondly If I push hard it will make a huge popping sound,ithas to be from the carb. The engine seems to run fine in idle butunder pressure it seems to struggle. All vaccuum lines seem fine except the top one in back, but that one seems like it has no effect when removed. Any ideas?
05-12-10, 07:21 AM
Popping through the carb could be a bad cam or burnt/bent valve. The only 307 I ever had burned a valve. A compression test and vacuum test will verify and/or rule out those obvious things. Those transmissions aren't exactly bulletproof either. Do you suppose that car had a few hot driving before it was sold?
06-23-10, 11:03 AM
timing? bad plug wires?
