: Reverse adjustment mirror dont work ...
05-08-10, 02:05 PM
hi, i want to know if its normal or i should get my car in for repair on the warranty, when i back up the passenger side mirror goes down like you all know but not for the driver side, is it normal ?
thanks a lot
05-08-10, 02:12 PM
The passenger side mirror tilts down when you put it in reverse to allow you to see & avoid the curb while parallel parking.
Unless you live in Great Britain (or certain other countries), there wouldn't be a whole lot of usefulness in the driver's side tilting down.
If you never parallel park or do a lot of backing up where you might run over small dogs, you can disable the feature.
05-08-10, 02:59 PM
i often back up my boat to load the ramp so yes for me its a good feature to see if my aligment is correct in the ramp.
so its normal that it tilt only 1 side.
05-08-10, 04:04 PM
both driver and passenger side tilts.In the driver info center you have the option for passenger,driver or both to tilt.So check you DIC to make sure it is set for "both"if you want both to tilt.
