: Here is an interesting problem!
alanhoggard
05-04-10, 07:03 PM
I have a 1995 Eldorado, it cranks, no start, it has spark. If I spray some starting fluid in it, it starts right up and runs great until i park it and try to start it again. sometimes it will start 2 or 3 times, then the next time just cranks and cranks, until I hit it with the starting fluid. any ideas? Cam sensor, ICM????
Thanks, Alan
tateos
05-04-10, 07:55 PM
Neither, I think. Maybe the theft deterrent system. Pull the codes.
alanhoggard
05-04-10, 10:55 PM
OK, I will pull the codes in the morning, all I looked for was the P codes. What letter will I be looking for to check the antitheft? I also have a service engine soon alert!
cl1986
05-04-10, 11:05 PM
fuel pressure?
Ranger
05-04-10, 11:49 PM
:yeah:
cl1986
05-05-10, 12:21 AM
let me know if it is, ill be throwing away a good pump here shortly off a 94
alanhoggard
05-05-10, 10:02 AM
I don't think it is fuel pressure because once I start it it with the starting fluid it runs fine. I am stumped.
alanhoggard
05-05-10, 10:24 AM
OK, here are the codes
P, 020, 052, 071, 109, all history
A047, current
S, 036, 038, current, 044, 072, 073, history
NO, IPC, SIR, TCS
Ranger
05-05-10, 01:17 PM
Please post the codes AND descriptions.
alanhoggard
05-05-10, 02:14 PM
Sorry, what do you mean by descriptions
Thanks
Submariner409
05-05-10, 02:38 PM
as in............... P020 = Open fuel pump circuit
......................P052 = PCM memory reset
from the OBD-1 tables in the "how to pull codes site", link to "prior to 1996......"
Ranger
05-05-10, 05:24 PM
Thanks
http://myweb.accessus.net/~090/dtcobd1.html
alanhoggard
05-05-10, 06:58 PM
OK, here are pcm codes.
P020-open fuel pump circuit, i did pull fuse to check it.
P052-pcm memory reset
P071-intermittent map signal
P109-keep alive memory lost power
all history
Thanks
cl1986
05-05-10, 09:16 PM
well that just about takes care of that.....one of the main suggestions is fuel pressure and you have had a fuel pump code.....
check the fuel pressure now already LOL
Ranger
05-05-10, 10:44 PM
Sounds like the pump is intermittent. If it starts and runs with starting fluid I'd suspect the relay maybe.
Necrosan
05-06-10, 01:01 AM
I had same code & symptoms.
Verdict: Drop tank, replace sending unit/pump. You can chance just changing the sending unit.. Dropping the tank is lame though.
zonie77
05-10-10, 01:16 AM
You may have some pressure, not enough to start but enough to run, or you may have and old pump that does not start every time. I'm betting option 1.
And yes, I have seen that before.
n* rider
05-20-10, 01:54 AM
I had this problem a month ago, and it was because my cooling fans were straight-wired to my fuel pump relay. Needless to say, it shorted the relay. I didn't find it until AFTER I had already replaced the fuel pump and it still didn't crank...
