rodcole1
08-25-04, 06:58 PM
Does anyone know how to reset the the message reminder. I have my oil changed at Jiffy Lube and need to reset the reminder or turn it off telling me that my oil needs to be changed.
Thanks.
Thanks.
| View Full Version : Message Reminder rodcole1 08-25-04, 06:58 PM Does anyone know how to reset the the message reminder. I have my oil changed at Jiffy Lube and need to reset the reminder or turn it off telling me that my oil needs to be changed. Thanks. hcvone 08-25-04, 07:13 PM Not sure if 02' is the same as 03', but with thye 03' get the oil life on the DIC, and hit the reset button and hold for 5 seconds, that is the button under the volume control, it will reset to 100% . :) slk230mb 08-25-04, 08:33 PM Put the ignition to run, engine off, step on the gas pedal (floor it) 3 times and the info center should flash a message that it was changed. T_Dogg8 08-26-04, 08:28 AM Not sure if 02' is the same as 03', but with thye 03' get the oil life on the DIC, and hit the reset button and hold for 5 seconds, that is the button under the volume control, it will reset to 100% . :) i don't think the 02s have an oil life section on the DIC. just fyi :) Sta11ion 08-26-04, 10:31 AM Thats the right way to do it.Put the ignition to run, engine off, step on the gas pedal (floor it) 3 times and the info center should flash a message that it was changed. rodcole1 08-26-04, 04:25 PM Thank you, I will give it a try tonight. Rodcole1 Cadillade 08-27-05, 01:22 AM Put the ignition to run, engine off, step on the gas pedal (floor it) 3 times and the info center should flash a message that it was changed. It would be more fun with the engine on :D | |
