View Full Version : Just took delivery on my '04 CTS-V, need to replace rotors/pads.
brok3n
04-29-10, 12:24 PM
As the title states, I need to replace the front pads/rotors. The previous owner let them go for WAY to long and the front passenger rotor is showing a groove on the inside edge of the rotor... I can probably get away with turning the rears and just replacing the pads.
My question is, I went to Murrays to look for pricing and they have two different front brake rotors, supposedly for the two different suspension setups that were offered on the CTS-V. (FG2 and FE4)
Is there any difference in the front rotors between the two suspension setups? I wouldn't think there would be because if what I read was correct they just replaced the rear shocks with monotubes.
Any help/insight would be greatly appreciated.
Thanks,
-Mike
ctsv154
04-29-10, 12:35 PM
Front rotors are the same regarless of suspension. FG2 is just a stiffer stock.
brok3n
04-29-10, 12:36 PM
That's what I thought. I guess I'll just get the cheaper ones then...
rjoffe
04-29-10, 03:02 PM
Don't go cheap on rotors, otherwise if you start using the car for what it was designed for (road track) you will be replacing them in no time.
brok3n
04-29-10, 03:35 PM
For the time being I'm just going to be driving it back and forth to work. My plan is to see if I can get some DBA or Powerslot rotors down the road... but it's pretty much undrivable at this time. Thus, cheaper is the winner.
