: Got the serial number off my diff ... which version do I have?
WesH8398
04-27-10, 12:09 AM
I'm not sure which number is the identifying one, so here are the 2 numbers I got off the GETRAG sticker on my diff ... 0000645001209E and 00000NRJ-00112. Just curious... Which version of diff do these correspond to?
Houdini
04-27-10, 08:46 AM
Those don't appear to be the part numbers. You need to get the part number that is above the barcode. I think the only way to see it while the diff is still in the car is to hold a camera phone up there and try to snap a few pics. You'll be doing it mostly blind. The part number is on the top right side of the sticker just above the barcode.
WesH8398
04-27-10, 09:48 AM
Ahhh, crap. Those were the 2 numbers I could see when the car was up on the hoist at the muffler shop the other day. One was below the barcode and the other was above it. Guess I need to try again... Thanks for the info!!
Houdini
04-27-10, 02:46 PM
Ohh and check out this thread for diff versions/part numbers. There is a picture in there showing the part number listed on my actual diff sticker. That will give you an idea of where it is at:
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/193934-2nd-gen-diff-vs-3rd-gen.html
CancerJCC
04-27-10, 04:52 PM
Yep took me probably 30+ shots with the digital and a flashlight to be able to finally make out the first few digits to get an answer...
Cadillac Cust Svc
04-27-10, 07:17 PM
I would like to take a look at this. I would like to direct message you to get some more information. Thank you for your time and cooperation.
Jeff Morris, Cadillac Customer Service
WesH8398
04-27-10, 11:51 PM
Guys, is this for real? Sounds like spam/crap to me ... :thehand:
Stepside
04-28-10, 12:25 AM
Those numbers are probably from the sticker on the cradle near the pinion.
The Diff # is on the back right side of the rear, just off center.
Too see it, you will need a flashlight and a mirror and it can be done without a lift. Just put down a big piece of cardboard to slide around on and crawl under there.
Too take a picture of it, it is trial & error to point the camera at the precise angle to get a picture. If the number starts with 157, its the 3rd part number 'Gen' rear for '06-'07 and if it starts with 258, it's the latest part number 'Gen' introduced in '08 for 1st CTS body style. Diff #s starting with 103 or 123 are . . . :eek: . . POS.
Have fun. :)
WesH8398
04-28-10, 09:30 AM
Thanks Stepside. I want to change my diff fluid anyway, so when I'm under there doing that, I'll try finding the part number again.
