: Spark Plugs
04-23-10, 02:52 PM
Can anyone tell me the best plugs to get? Sorry if this sounds like a dumb question...just heard somewhere that you shouldn't use just any type of plug on the N*
04-23-10, 02:58 PM
AC-Delco, Platinum tips. OEM kind.
04-23-10, 04:15 PM
If the car has the Northstar engine you want AC Delco #41-950, gap is preset at .050", torque to 13 ft/lb with a tad of anti-seize on the first three threads. Use the diagram to correctly connect the plug wires.
04-23-10, 04:19 PM
For your Northstar, use AC Delco 41-950 .050" pregapped spark plugs. That's the one and only spark plug which will last long / give you an easy life.
04-24-10, 11:49 AM
Thanks all! Got em ordered...wire set as well
04-24-10, 03:42 PM
Make sure you get the AC-Delco wire set.
07-31-10, 06:40 PM
Were is the best place...cost wise...to order a set of AC Delco wires for my '96 SLS?
08-01-10, 10:03 AM
www.rockauto.com - the expensive set is the GM sourced correct length with the proper boots.
Make sure you hook up the wires correctly. use this diagram.
