: HID upgrade for a 2000 Deville
Oldman Cadillac
04-19-10, 01:03 PM
I have a question about upgrading to HID's. My 2000 Deville has 9006 low beams that are also day-time running lights. Will I be able to use the 35w or 55w HID kits for my low beams if they are on all the time? Or will I have to disable it? Thanks in advance.
SharpHID
04-19-10, 01:24 PM
Hello,
You are able to use either 35w or 55w kits on your vehicle. You will require the battery harness with either kit. The daytime running lights should not cause any problems. You can leave then enabled.
Regards,
John
Oldman Cadillac
04-19-10, 03:17 PM
Thanks for the quick answer. What does the Battery Harness do?
SharpHID
04-19-10, 03:53 PM
The battery harness means that main power is pulled from the battery rather than your OEM wiring. Your headlight switch still controls the lights however.
Regards,
John
baller95
11-08-10, 06:43 PM
Hi I have a 2000 DTS with day running lights aswell (Canada) and I was wondering what is the best HID kit I can buy for the best price !
SharpHID
11-08-10, 06:56 PM
Hello,
Really any of our kits here: http://store.sharphid.com/category_s/1.htm will work for you. Simply order according to the bulb type. Our Limited Edition kits are great value for money right now and offer a simple compact installation.
Regards,
John
baller95
11-08-10, 07:05 PM
Hello,
Regards,
John
Thanks for the info John, I was wondering if you have any retrofit projectors for my car also. Thanks
SharpHID
11-08-10, 11:50 PM
Unfortunately we don't at this time.
