i have replacement air shocks on my 89 brougham. the shocks seem to hold air for maybe 24 plus hours then they deflate. i have checked the lines and everything else that is possible. oh i 'am filing them manually, but i do have the self inflate compressor under the hood, but they leak if filled from there also. any and all sugestions will be helpful.
ompa50
DaveSmed
08-22-04, 07:07 PM
Assuming the shocks are not the cause, the plastic lines tend to get brittle with age. Easy to find which one if you fill a spray bottle with soapy water, and spray the fittings. The one that bubbles is the culprit.
STS 310
08-22-04, 08:52 PM
Valve stem might be a culprit. But as Dave pointed out, those lines do get brittle with age.
thanks for the suggestions. changed 1 of the lines 2 days ago and the shocks are still holding air. how it conts.
ompa50
