: 07 Escalade DVD wont eject
h0wir0ll48
04-06-10, 07:59 PM
i inserted dvd into the dvd slot (non nav) and it played fine then when i went to eject it wont eject or do anything at. after i hit eject it go to radio waiting for it to eject then 5sec later turns radio off and says loading disc and starts playing again but wont eject i tried taking the fuse for the radio out and leaving it out for 10min and then trying again but that didnt work. any idea how to get it out its like the mechinism is just holding the disc not releasing it.
thanks in advance,
blake
steve841
04-06-10, 08:01 PM
I believe there is a software update to fix that .... dealer service.
http://tis2web.service.gm.com/tis2web
Search around on this site...
h0wir0ll48
04-06-10, 08:05 PM
so take it to dealer... anyway i can do it myself? im pretty computer able.
dixit
04-07-10, 09:33 PM
When I have issues like this with my DVD player (factory) up front with burned DVDs, and it just refuses to do anything, only way I can get it out is eventually to pull the fuse for the entire radio/headunit, and as soon as I put it in (preferably a 2nd person inside) start hitting eject and it usually comes out.
Dixit
Escapade
04-08-10, 04:45 AM
^^^ so this step requires removing all the panels.... can removing a fuse from under the hood do the same thing? Or does it really have to be from the unit itself.....
surburban99
04-08-10, 09:32 AM
The six disc CD player (music) in my 08 ESV has been doing the same thing. Won't eject.
Could this be related to the software update as well?
dixit
04-08-10, 10:09 AM
You dont have to remove any panels, as I stated before pull just the radio fuse. Its located under the hood fuse panel. As soon as you get it in, just start ejecting the disc(s). It goes into a full startup mode and the buttons do work to eject.
I have this problem at times because it seems the headunit is really particular about DVDR and how they are burned. It doesnt like some of them and then read the disc, freezes, and refuses to do anything, wont even change to another disc. This is the only way I can get it to eject.
Dixit
Neoex
04-08-10, 11:46 AM
I had an issue similar to this, I disconnected my battery, tapped my unlock button a few times to drain an remaining juice, reconnected battery, and was able to eject my discs
